Jointing an incoming SWA | Page 2 | on ElectriciansForums
Discuss Jointing an incoming SWA in the Australia area at ElectriciansForums.net
W
willowwaters
Hello,
Wondered if anyone could help. Im jointing a SWA incoming feed under the floor in a bungalow.
Is it ok to use 6mm T+E in a joint box and take it 2 metres up the wall to the new position in the incoming supply of the dis board?
Would appreciate your comments.
Craig
you can down the size of a cable, but not just because it suits you
i've run larger cables from the source of supply to a motor on site, the cable size required for the motor was smaller than the supply cable we put in, so we dropped the cable size (to the original rated size) via a junction box local to the motor, then ran the tails straight into the motors connection box.
btw. the reason we ran a larger cable was to accomodate voltage drop over the long run required
Reply to Jointing an incoming SWA in the Australia area at ElectriciansForums.net
Sounds more positive.
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
