P
Phillcbr400
Pretty simple question really,
Is it ok to use existing holes in joists when running in the cables?
Phill
Phill
Discuss joist cabling routes in the UK Electrical Forum area at ElectriciansForums.net
Haha cheers lads, this is for the first fix in my own property and going through LBC so don't want to give the inspector any excuses to spit his dummy out. And any new holes I drill will be within the tolerances but wasn't sure if I could use the old If they don't comply with the current regs. Plus how would I prove I didn't drill any holes that don't comply! Pics maybe?
With 'regs' like these, the specs they are saying are massively over engineered (for want of a better phrase).
You could cut a joist all the way through in the middle of a floor, with all the boards nailed down, it wouldn't collapse!
My house, 1910ish, joists have holes and notches all over the place, strangely enough I haven't fallen through the floor yet.
Reply to joist cabling routes in the UK Electrical Forum area at ElectriciansForums.net
