sparx24
Lost my 'jokari' yellow stripping knife, need to replace it ASAP.
It's no longer in their catalogue!
The type has a spring loaded top metal guide, a blade fixed to it.
An adjustable internal cranked blade with depth of cut set by a rotary screw at the other end.
In use you slide the top plate up and over the cable, turn the whole knife 360deg., then down length of cable.
End result perfect removal of outer sheath of SWA.
Help!
Help!
