JSB FX3302 Fire alarms | on ElectriciansForums
Discuss JSB FX3302 Fire alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Dmeltd
Would anyone have the software or know where to get the software for the fire alarm panel JSB FX3302?
I want to add to an existing system and not have to pay through the nose to get it commissioned
I have tried them, the unfortunate thing is that the FX3302 is now obsolete and there is apparentley no more support on that item
typical!
not having seen one of these panels, i don't know what type it is. is it a conventional panel with eol devices and sounders on separate circuits to the detectors?
Reply to JSB FX3302 Fire alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
