Junction box question | on ElectriciansForums
Discuss Junction box question in the UK Electrical Forum area at ElectriciansForums.net
Liam864
Essex
Can I run a junction box from the outside of my house into a light and run it from there.
Its an internal light.
Also the description is rather ambiguous. It sounds like you asking about powering a new interior light from an existing outside light? Or is it the other way round?
A bit more background would help.
I want to position a junction box outside but run the supply from a light in the hallway.I would take cable up outside wall into and throught a void to where the light rose is,and attached the box wiring to the light wiring.
Reply to Junction box question in the UK Electrical Forum area at ElectriciansForums.net
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
