G
greeny
You know how your tube of silicon sealer has gone solid just when you most need it!?
Do you think that one could use this problem to make a permanent water tight joint, eg using twisted conductors secured in the usual connectors and placed in a suitable small plastic tubelike container and then fully filled with silicon sealant. Leave it to go solid whilst using it as an insulator.
I do know that resin filled methods already exist.
