Just check a few Solar edge system | on ElectriciansForums
Discuss Just check a few Solar edge system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Heywood Lancs
Just check a few solar edge system and seen this one doing really well
3.95 kw Samsung 247w x 16
south facing
40
southcoast.:sultan::sultan: [ElectriciansForums.net] Just check a few Solar edge system
lol lads ok who got the biggest graph:) listen i rec its gonna be a BUMPER (MEGAWATT) summmmmmer:) so we will all be winnnnnners!!! esp on the 45.5p !!! grass may be dead but the banks balance will be good!!!
we need 2 grand a week not a year ..cant afford to retire yet if only I had 52 pv systems....awell...
That would be nice along with having the capital required to purchase 52 systems!
So, Solaredge. What's so special about it? I've seen it mentioned a few times here but am non the wiser.
Solar Edge uses an optimiser on each panel and an inverter with no tracker. End result is that each panel gives of its best and they don't all get dragged down if one is in shade. Means you can run panels on, say, a south-facing and a west-facing roof on the same inverter with no loss of overall performance. Go to Solar Inverters, Power Optimizers and PV Monitoring | SolarEdge for the full info, and have a look at their movie downloads which makes it easier to understand.
PJ
Indeed, I have 10 panels facing south (with some shading), 3 facing east and 3 facing west. The only solution that made sende was Solar Edge and it's doing exactly what it says on the tin. I'm very impressed with the performance.
Each optimiser works with all the the others to create a fixed string voltage of around 330v. It bounces up to this in very low light levels and the inverter starts generating at only a few tens of watts.
Not inverters, and the inverter is less complex so less costly. Overall works out a bit more expensive than a straightforward system, but equivalent to or less than having two inverters in the two roofs scenario. I've only installed one of them but it's doing the business. The OP seemed to suggest the one he'd seen was on an all-south roof - wouldn't bother with it there unless a lot of shading issues, but it's worth a look for a multi-directional roof setup. Have a look at their videos. It's a solution, not necessarily THE solution.
PJ
Reply to Just check a few Solar edge system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all. OK... Let me just try and clear a 1" square space on the screen inbetween all the highly intrusive ads.... On a site (NHS in fact) and...
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
