just live & S/L conductors in a metal enclosure ? | on ElectriciansForums
Discuss just live & S/L conductors in a metal enclosure ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
england
Hi
I am installing a Teletask Micros+ metal enclosure
Is it ok to bring just Live and SW Live conductors though a 400mm by 20mm slot cut in the rear of the enclosure ( sometimes cut in the base )
I know I have to bring L N CPC conductors through the same hole but the N and the CPC conductors are all terminated in the large plastic trunking which is mounted underneath the panel to keep it neat & because there is not enough room in the metal panel for them all
Thank you
I believe that with live only, into and out of the metal cabinet, a magnetic field will be generated around that conductor and circulating currents will be induced into the metal enclosure around the conductor,it could result in a build up of heat if that cable was passing a high current
Surely if you've a line in and a switched line out the same hole, the magnetic effects of the cables are cancelled out by each other.
Only happens when the current returning passes through a separate hole in a ferrous enclosure.
Correct.
Reply to just live & S/L conductors in a metal enclosure ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There is no homework, and I'll never see these photo again.
