just started out | on ElectriciansForums
Guest viewing is limited
Discuss just started out in the UK Electrical Forum area at ElectriciansForums.net
demkap
Hi there everyone,
Im a qualified niceic sparks and i was just wondering how much i should charge for changing over 7 lights to standard pendants.... im based in the london area and the job is round the corner from me.
If i was changing 1 id probably charge between £50-65 labour but as its 7 what price do you think i should charge.. cost of materials is £45
Cheers
Dem
Hi there everyone,
Cheers
Dem
how long will the job take?
at least half a day.. i was thinking £20 a fitting plus materials dunno if that sounds to much
4 hours at your hourly rate plus materials. bobs your uncle
as he said really. the amount of hours it'll take you multiplied by your hourly rate, plus the materials. obviously with your mark-up on top.
not rocket science is it mate!
Demkap,do you base your hourly rate on how much you can achieve in that hour or on your qualifications and niceic membership? you being a qualified spark and all that.
How would you price to second fix a house that you didn't first fix ?
Price per fitting or day rate?
I'm not having a dig at you, I'm curious .... honest
Put together a pricing menu on a per-fitting basis and you'll always be unhappy. Add a socket? If it's in the next room and back-to-back with an existing one, or right next to an existing one that's a pretty quick job, especially if it's a stud wall. But if the socket's on the other side of the room from the nearest cable, and you have to go under the floor? Or if it's a solid floor? Can't have a fixed rate per socket for that lot.
Change a light fitting? Should be straightforward, but what if the ceiling is 20 foot high and you're fitting into a plaster rose? Or the fitting has to be put together, with three layers of dangly crystal thingies!
pj
Hi there everyone,
Cheers
Dem
[ElectriciansForums.net] just started out
Reply to just started out in the UK Electrical Forum area at ElectriciansForums.net
What attracts me is, i enjoy working in trade i like keeping busy an grafting an getting to be proud when a job is finished, with the electrician...
After fitting out the first room of downlights.... i expect him to get a bit speedier at fitting them There is so many unknowns to price at this...
Recommended Sponsor News
Hi everyone,
