Guest viewing limit reached
The Practicals are straightforward, and two of them can rightly be described as easy.
The 12 observations board can be a little difficult, just look at everything in turn, and put down what is definitely wrong - one I didnt spot until the end was a pendant flex not gripped by the cord grip.
The main board PIR is nerve wracking, but, if done logically, it is no different to any normal testing you do every week. Safe lock off etc, then do the tests in the right order etc. The only thing to worry you will be your own nerves. The next day, you will realise there was not a lot to it, but at the time it looks daunting.
Good luck.
Hi guys, I suggest we just wait and see now, no need to worry about petty stuff. Mid December is our "D" day. Let's meet back up on here in two months time to share our joy!!!!!!! or sadness for the unluckiest ones...:willy_nilly:
Now my next step is hammering the practical courses on tuesdays and thursdays! I wanna it done and dusted by chrismas!!!!! Guys we deserved this 2391 ****ing hell!:coolgleamA:
did mine this week,4hrs prep before 2.5 writting the paper 2hrs drive home from college ,sore eyes sore fingers and wrist
boooooooo i need the results before the new regs start or ive got even more revision ,why does it take so long
Just took my 2391 theory exam tonight!
gman67,
AndrewDavie,
