hi hope someone can help I am in the middle of a kitchen remodel and the fitters have a problem with my wiring. We are have a oven and a fitted microwave both needing a 16 amp Rcd supply. The old cooker is on its own but not rcd but that not a problem I have a spare mcb in the consumer unit. The problem is with the microwave. I have a double socket that can be change to a cooker switch with a single socket which is rcd protected. Would this be ok or do I need to put in a separate supply for it. Hope someone can help.
