Kitchen Questions | Page 2 | on ElectriciansForums
Discuss Kitchen Questions in the DIY Electrical Advice area at ElectriciansForums.net
Hi Guys - excuse the long first post.
A neighbour has just had a kitchen installed with the inevitable electrical work being done by a company.
Can I ask a few questions regarding regs? The house is in Scotland, so no mandatory Part P as I understand it. Correct
Cables - I thought that all T&E should be supported every 250mm horizontal runs and 400mm for verticals - the spark has not clipped any cables I can see - including the heavy cooker cable that runs under the floor back to the consumer unit at any point in its run, and also on a couple of other 2.5mm t&e runs from existing dishwasher outlet locations to the new one - same for a few runs of 1.5mm for the lighting. Am I correct in thinking that there should be no exceptions to the 250/400 rule? Sounds a bit rough - a couple of photo's would be helpful
Location of 13A sockets - the spark has placed a single non switched socket right next to the mains stop cock - probably 100mm away from it at best - I had read of a 300mm guideline for any socket to be "away" on the horizontal plane from any sink or tap - is what has been done appropriate? There is NO stated minimum distance (which is daft). The Electricians guide to the building regs mentions 300mm but this isn't in BS7671
Under cabinet lighting - the spark has taken an existing under cabinet lighting circuit down to the floor level in 1.0mm t&e and then terminated it in a single non switched 13a socket. I thought that this was not permitted as all 13A sockets should be fed by at least 2.5mm t&e or have a fuse/breaker of an appropriate size inline where the cross section changes? Has he had to use a 13A socket to incorporate a plug type PSU/transformer? Sometimes this is the only way.
Next, there was earth bonding under and onto the existing sink. The spark has left the main earth loose around the mains water feed - just after the stop cock (where it should be I believe, think regs are within 600mm?). Issue here is its loose - and the spark thinks its not needed at all. My understanding is that as its the mains feed into the building, it should be a good earth (connected tightly) and I agree that sink and tap pipework bonding is no longer needed. Can you not tightend it up for your neighbour? Again a bit ruff and rushed.
The spark has buried several junction boxes (screw terminal not crimp) and power supplies (little switched mode ones) that supply under the wall cupboard lights actually into the wall (plasterboard) and they are just pushed in there not screwed or fixed to anything. Is this permitted? Not allowed but many do this which again is very rough.
Lastly - should I expect a "Select" certificate covering all the work that the spark has touched? If not, what should I expect to see on the cert? I was told a cert would be issued. I would recommend your neighbour withhold payment until the paperwork is forth coming.
Thanks in advance for all your help and advice.
David
COmments in bold above
Are you part of this trade?
I would say that electricians that know the regs will install to the regs we are not all cowboys.
No, as said a few posts ago, I am not in "this trade" nor have I ever been, but I do cross paths with sparks from time to time, but are not responsible for the work or standards that they adhere to.
- - - Updated - - -
THANK YOU!!!!!
- - - Updated - - -
THANK YOU!!!!!
I get the distinct impression that if I were playing cards against you, you would want mine laid out on the table, face up, whilst yours would be firmly locked in a safe.
Finding it a bit tricky to do a multi quote reply here..
Cable runs - he has not used any clips to secure anything I have seen - dishwasher, lights, even the big cooker cable (which I assume will be 6mm or perhaps heavier (?) which runs down the back of the unit and under the floor and emerges at the CU where there is one solitary clip as it crosses the skirting board. Some cables are "jammed" between the plasterboard and floor, some just left to sit as they lie.
Socket beside mains - thanks - I did not think there were rules there other than the 300mm I had read about. Seems senseless where he fitted it (surface box on a plasterboard wall) when it could have been behind the actual dishwasher and distanced from all the usual under sink pipes and taps.
Lighting - no - there is a cable with twin going into barrier strip and off to the lights, hence I question why he presented it on a 13A socket. Is there not a rule that says you cant present a 13A socket as it could be reasonably expected that something that needed 13A could be plugged in there... and the 1.0mm would be on the limit with the original long runs within insulated walls. I guess it does not matter in reality as long as the mcb protecting it was 6A or similar.
Water mains earth - is it code that it needs to be within 600mm of stopcock or did that go the way of earth bonding everything in the kitchen? I will tighten it, but I guess the question is that of is it needed these days?
Junction boxes etc in walls - are they allowed if crimped or just not at all? I certainly would not want any PSU to be behind my kitchen tiles as we all know it wont last for ever, especially in an insulated cavity!
Cert - my thoughts exactly - they wont pay at this point. Should the cert cover every circuit that the spark has modified or installed?
Thanks guys... I was beginning to give up hope:dizzy2:
David
Thats amusing!
Nah, I 'aint like that, honestly... It really does p*ss me off when folks pay (or are about to pay) good money for a job and you get some guy do shoddy work - as said in the replied above "rough"...
In my original post I did try to describe the situation and my understanding of what was right and wrong...rather than post just questions... I tried to offer what i *thought* was best practice or the expected approach.
Having said all that... if you ever do want a game of cards... I'm in... hehe
Socket beside mains - thanks - I did not think there were rules there other than the 300mm I had read about. Seems senseless where he fitted it (surface box on a plasterboard wall) when it could have been behind the actual dishwasher and distanced from all the usual under sink pipes and taps. Absolutely NOT, a socket directly behind a washing machine is not accessible for isolation unless there is an isolation switch above the worktop
Lighting - no - there is a cable with twin going into barrier strip and off to the lights, hence I question why he presented it on a 13A socket. Is there not a rule that says you cant present a 13A socket as it could be reasonably expected that something that needed 13A could be plugged in there... and the 1.0mm would be on the limit with the original long runs within insulated walls. I guess it does not matter in reality as long as the mcb protecting it was 6A or similar. You have NOT answered my point about the 13A socket being required for a PSU
Water mains earth - is it code that it needs to be within 600mm of stopcock or did that go the way of earth bonding everything in the kitchen? I will tighten it, but I guess the question is that of is it needed these days? 600mm "where practical"
Junction boxes etc in walls - are they allowed if crimped or just not at all? I certainly would not want any PSU to be behind my kitchen tiles as we all know it wont last for ever, especially in an insulated cavity! No junction boxes are crimped to my knowledge, So has he crimped and then contained the crimps in an enclosure for added protection?
Cert - my thoughts exactly - they wont pay at this point. Should the cert cover every circuit that the spark has modified or installed? Definitely. MWC for each modified and an EIC for each new one.
David
So are you going to post some photo's or simply use internet based feedback to have a go at a spark?
Reply to Kitchen Questions in the DIY Electrical Advice area at ElectriciansForums.net
Thank you for your quick and excellent response - I hadn't thought about the cables changing over time. I'll replace all three. Thank you once...
T
Water appearing in washing machine when run kitchen taps Hi there! When I run hot or cold kitchen tap, clean transparent water slowly appears in...
T
