O
OlafIrolp
Hi, so in my fuse box i have an old shower 6mm cable that has been redirected to be used as a kitchen ring (split in to two 2.5mm). My question is the cable runs trough the loft (top floor flat). I have had the loft insulated and read that cables the run close there their load should run over insulation (which is done) so they don't over heat. But i am concerned about the roof ambient temp now?
