Kitchen sockets issue. | Page 2 | on ElectriciansForums
Discuss Kitchen sockets issue. in the UK Electrical Forum area at ElectriciansForums.net
West Midlands
Hi all, can I ask if anyone has ever had a problem like this.
i was called to a property tonight, the tenant had turned on their kettle and it had switched off at boiling point but continued to boil.
They have tried 4 other kettles and they've all done the same thing.
ive tested the circuit, a 16A radial for the kitchen, and there is nothing unusual.
However there is no earth to the property, I was unable to gain a Ze reading.
i'm returning tomorrow to install an earth rod but will this solve the problem?
This is a new problem to me.
If anyone could shed any light I'd be massively grateful.
James
If you have only tested 4 kettles you will not have accurate results, you need to test a further 6 kettles, install the earth rod and then you should be able to make a brew.
I had a customer once tell me their iron would never heat up properly when plugged in to one particular socket, but everything else worked fine on this socket. Tested fine, conclusion do-lally customer!
I'd have probably just replaced the socket for them (for a fee) and told them that the problem was fixed. Otherwise they won't believe you that there's nothing wrong.
Reply to Kitchen sockets issue. in the UK Electrical Forum area at ElectriciansForums.net
