thanks lenny
Just to clarify; Bonded rather than through the CPC? Or would either method be acceptable?
It is a domestic propery but the plans are for a very small tearoom
Hey.
It's the same principal as supp bonding in bathrooms whereby all cpc's of all circuits within the bathroom are joined together in 4mm single earth cable to any pipework.
I would do the same, take a 4mm from the socket outlet and bolt it to the splashbacks somewhere out of site if possible.
Hope this helps.
Lenny.
If somebody drills through the splashback ie put a shelf up etc and drills into a buried cable and screws into it then the splashback could become live !
Do take point though as kitchen sinks dont need bonding etc and water pipes are bonded so sink will be and pipes by the rising main. better to bond everything.
I have posted the following in relation to previous comments regarding metal tables in a kitchen, but Regulation 8 still applies.
Can I bring the 'Electricity at Work Regulations 1989' to your attention. As you are aware these regulations are statutory and it is a criminal offence if you have not taken reasonalbe steps to comply.
Regulation 8 states as follows; "Precautions shall be taken, either by earthing or by other suitable means, to prevent danger arising when any conductor (other than a circuit conductor) which may reasonably foreseeably become charged as a result of either the use of a system, or a fault in a system, becomes so charged; and, for the purposes of ensuring compliance with this regulation, a conductor shall be regarded as earthed when it is connected to the general mass of earth by conductors of sufficient strength and current-carrying capability to discharge electrical energy to earth."
So the metal table which is a conductor must be earthed if a piece of electrical equipment is intended to 'sit' on the table.
Sorry this reply is drawn out but it is important that these regulations are followed in addition to the IEE Regs.
Kitchen stainless; exposed or exrainious?
lionelmcc,
Bernieg,
