Kitchen upgrade costing? | on ElectriciansForums
Discuss Kitchen upgrade costing? in the UK Electrical Forum area at ElectriciansForums.net
Snapester
Hi guys, just priced a job and i think i may have priced to much?
Basically it is reconfiguring the original ring and adding extra points, points on view and cooker switch to be MK Brushed chrome about 3-4 sockets on view. Rest in white goods under counter etc. Cooker wire already in place and using existing. Having to add RCD enclosure to protect sockets as original board has no RCD and not one available. Circuits to be sheathed and buried.
There are also 7 spots to install and also need to add gas bonding and water as non there currently.
Then test and certify.
Estimated 2 days work and materials ÂŁ927
Cheers in advance.
Providing all materials 7x 12v Downlighters Mk Brushed chrome switches and cooker switches and lighting switches.
Work is ripping apart original circuit and rerouting and adding about 5 sockets and moving older points. All work to be sheathed up and flush.
Spark and a mate.
Cheers
Reply to Kitchen upgrade costing? in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
