B
ben9790
Hi All,
Im looking at refurbishing the kitchen.
I'm getting an integrated single electric oven that runs max at 2.9kW and an electric hob that runs max at 6.6kW. i already have a 32amp circuit for the old cooker in situ. can i run both the cooker and the hood off that same 32amp circuit?
I also wanted to have a grid switch with separate switches for the cooker and hob. can I do this, as i have the old black and red 6mm cable and am not sure if it will even fit into the rocker switch terminals?
then i wanted to use another 32amp circuit already in situ for x2 double sockets and the rest of the appliances. i.e. washer/dryer, hood, microwave and fridge freezer. (is it essential to have the fridge on its own unprotected circuit?), think the boiler is on this circuit too.
i would have sockets local to the appliances and again have them run through the grid switch above the work top.
am i ok doing it like this or do I need to change anything?
thanks.
Ben.
thanks.
Ben.
