Kitchen Wiring | Page 2 | on ElectriciansForums
Discuss Kitchen Wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
guys......it was a simple question. i thought the point in these forums was to ask questions.
But, if you guys don't know the answers its fine no need to get defensive and embarrassed you don't know!
The point of this forum is NOT to spoon-feed chancers information on how to do there own electrics.
You have been given the best advice by several people.
Good luck :)
Well if he's anything like the project manager we are dealing with on a job at the moment then im not at all surprised.
Plenty of chancers out there. ;)
That probably explains why half the new builds and projects out there end up in the s*** state they do!! The people planning and monitoring them don't even know what they are looking at!!
im not a project manager in your field, obviously.
Ok so in which case you do not know enough to undertake or attempt such work. You are not qualified or experienced to do so. So instead of being 'sarcastic' by claiming others don't know when clearly it is you in the dark trying to leach advice from others to then dabble with something that could potentially kill you!!!
Reply to Kitchen Wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
The gas hob might still need to be plugged in for the ignition, but an electric oven should have its own supply. You may need to employ the...
Thats why somebody told you to spk to the sparky
