View the thread, titled "Klober cable outlet" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
16mm PVC Oval Conduit (CEF) grind out the back of the tile, pass up through the felt / membrane lap and mechanically fix it with a small screw into the rafter. takes 5 - 10 minutes per pair of cables.
Reply to the thread, titled "Klober cable outlet" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
