kodi exodus problems anyone help | on ElectriciansForums
Discuss kodi exodus problems anyone help in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
diditrain
north west
Is anyone on here, any good with troubleshooting watching movies or tv programs using an amazon firestick?
I have been using it to watch movies/tv programs using Exodus for about a year with no issues however, for the last two days I have not been able to watch anything.
When I select a movie or tv program, it goes through the normal routine where the time elapsed/ remaining providers pop up box appear and then it just seems to time out and nothing plays.
I have tried installing/uninstalling but this does not help.
Who is your internet service provider?? Im with sky, mine stopped working but it was down to the new sky shield, I just turned it off and it worked fine after that!!!!
Try a manual update of the exodus add on (even if you have auto-update on) that usually works for me. I upgraded to the latest Kodi (V.17) the other day and kept losing sound during films, uninstalled it and re-installed v.16 (Jarvis) - no more problems, plus I think its easier menu system.
We uninstalled in and installed v17.1 - works a treat. Failing that, you could use smpc which also works fine. It is based on Kodi.
Reply to kodi exodus problems anyone help in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
This is solved. Praise elder gods. I didn't touch the parameters any more but added a small 120 ohm resistor to potentiometer. The tiny control...
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
