B
Bhavesh Valand
Hi
I bought a 4 Kosnic LED Dimmable Lamp (KLED05DIM/GU10) to replace the Halogen bulbs and the compatible dimmer switch as recommended by Kosnic - http://www.kosnic.com/media/datasheets/data_powerspot_5wKLED05DIM_GU10_2012-V2.0_1.pdf
Varilight VPro 250W Dimmer - Once install and turn on light it flashing about 4 times and stay on and i can rotate to full power and all works and once i try to dim to lowest the light flashing again for 3 -4 times. I have not done any changes to mode on the vpro and reading through the documents it supports 2 modes. Wanted to check if any one have tried different modes and have any success?
Aurora AU-DSP400X - The result of the dimmer was a bit different, once installed and turn on lights there is no light and once i rotate the dimmer to all the way to half then i can see light coming on and goes to full power once is rotate to the other end. I thought this is a bit weird but better then varilight one so i left it and then after about 30 minutes of leaving it on suddenly one bulb turned off, thought for a second is gone but after couple of minutes it turned back on and at one point 3 bulb was off.
Any suggestions or setting that i should try to get it working for Vpro or Aurora Dimmer ?
