kosnic led lamps | on ElectriciansForums
Discuss kosnic led lamps in the Electrical Tools and Products area at ElectriciansForums.net
gutterball
Fife
Hi anybody use these? I put 8 down-lights in a hall and stairway about 18 months ago. (customer supplied lamps and fittings from amazon) 3 of them have now failed and i was wondering if it was poor quality led's or a bad batch. I normally use led hut ones or megaman from the wholesalers.
had the same with kosnic. 2 failures in 12 months on an install of 12.. always use smd's from convertabulb now. had 1 fail out of about 200.
Kosnics are total rubbish
Best LED lamp i have come across and use is the MEGAMAN MODO 4.5w
Fitted 100's over the past 2 years and had NONE fail at all
we use them from time to time at work along with osram.
at home im using lumilife led's they have been in a while and going strong (had a couple voltage spikes here and the odd power cut and no issue)
Reply to kosnic led lamps in the Electrical Tools and Products area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
OVIA IBEX 5W EMERGENCY LED SELF-TEST NON-MAINTAINED DOWNLIGHT
