kraus and naimer isolator | on ElectriciansForums
Discuss kraus and naimer isolator in the Electrician Talk | All Countries area at ElectriciansForums.net
T
TF and the wire
I have one of the above rated at 250amp and mounted on the door of a control panel, but its the actuator that I have a question about. It's supposed to be defeatable, so that normally the actuator prevents the door from opening unless the actuator is in the off position. But by using a tool, it should be able to be opened in the on position.
There is a tiny hole on the rotary part that is in line with a plunger on the inside, but I can't see how anything small enough to pass through the hole can exert enough pressure. A blue plastic key type thing came with it, but doesn't seem to fit anywhere.
Not sure if I have to open the hole out. Anyone used this type?
Reply to kraus and naimer isolator in the Electrician Talk | All Countries area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
I would think that if they are apartments, and not something like uni halls with private bedroom and communal facilities, then each one would be...
