kt64 | on ElectriciansForums
  • Thread starter bredon86
  • Start date
  • Replies 1
  • Views 2K
Discuss kt64 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bredon86
i have recently purchased i kt64 and have been using it for 1 week with no problems doing domestic pirs. this morning i came to use the machine and all tests were fine except for continuity where i keep getting a reading of greater than 1999. i changed the batteries and still the same. can anybody help? or know were i can get help from? thanks :confused::confused::confused:
According to the instruction manual, the continuity circuit is protected by a fuse. Please see below attachment, it explains where the fuses are and how to check them.
Hope this helps
  • [ElectriciansForums.net] kt64
Reply to kt64 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
You’ll need level 3 qualifications- 2391 or equivalent plus 18th edition to get on an PV course. To join a scheme and sign work off, I think...
