L-E 199v, N-E 199v ............... real readings | on ElectriciansForums
Discuss L-E 199v, N-E 199v ............... real readings in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
So these are the readings on a radial (serving the immersion and a socket in the loft) NOT connected to the CU ............. odd I thought - no direct connections between the 2 circuits
I have located the issue ........
Just for a bit of light hearted fun - anyone want to guess what caused it?
Mouse or other rodent chewed through cable?
Immersion switch with neon connected wrong? Ie supply into load side across the neon?
Nothing in the attic but glass wool. Ie no switch or light, just a cut cable sitting live?
Come on! The suspense is killing me!!!
So these are the readings on a radial (serving the immersion and a socket in the loft) NOT connected to the CU ............. odd I thought - no direct connections between the 2 circuits I'm confused, it's a radial serving two points but it's also two circuits?
A crappy generator not fitted with an avr
I destroyed a computer last week ...
[ElectriciansForums.net] L-E 199v, N-E 199v ............... real readings
Reply to L-E 199v, N-E 199v ............... real readings in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
