L-E 199v, N-E 199v ............... real readings | Page 2 | on ElectriciansForums
Discuss L-E 199v, N-E 199v ............... real readings in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
So these are the readings on a radial (serving the immersion and a socket in the loft) NOT connected to the CU ............. odd I thought - no direct connections between the 2 circuits
I have located the issue ........
Just for a bit of light hearted fun - anyone want to guess what caused it?
Ok, ok, it’s our wedding anniversary and we’ve been out for a curry
So the answer is that the GSR who fitted a new boiler in 2012, decided to use the N as the PL for the boiler and connect the neutral to the immersion circuit ...
Fixing this is going to be fun .....
What curry did you have?
Reply to L-E 199v, N-E 199v ............... real readings in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
