L+G 3ph Meter Error Codes | Page 2 | on ElectriciansForums
Discuss L+G 3ph Meter Error Codes in the Commercial Electrical Advice area at ElectriciansForums.net
I did come across the manual showing the larger number of display fields, but didn't consider it was necessarily correct for the ZMD120ASer53 model.
I noticed there is a meter selling on eBay with a similar, but different ('Ser' is 'Ptr') model no here:
interestingly the seller pastes a link to the manual in his listing, the same as the one in my post #4 !
Thank you both for all your help.
I have finally got a result from L&G after contacting their CEO, TWICE!
Sent: 13 March 2023 13:17
To: Egan, Simon <[email protected]>; Lieberherr, Werner <[email protected]>;
Subject: RE: ZMD120ASer53 Error code
Dear Andrew,
I have tracked down the error code that you are requesting assistance on.
Details of the error can be seen in the screen shot below.
The error code reflects to a measuring system error, and as such it is recommended that the meter be replaced.
The meter that you make reference to, was made end-of-life a number of years ago, but your energy supplier should have a suitable replacement meter.
You should contact your energy supplier with a request for the meter to be replaced.
Kind regards,
Scott
Scott Flatters | Landis+Gyr UK | Senior Sales Manager |
Reply to L+G 3ph Meter Error Codes in the Commercial Electrical Advice area at ElectriciansForums.net
I have an "old school" electricity monitor similar to this one...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
