lamp flashs when i turn off switch | on ElectriciansForums
Discuss lamp flashs when i turn off switch in the Australia area at ElectriciansForums.net
i replaced a incandescent bulb with a energy saving lamp, but the lamp keeps flashing, i checked the voltage in the ceiling rose, but no voltage at all, how come the lamp keeps flashing?
i have to use the incandescent bulb again.
anyone has come cross this before?
cheers in advance
This is a common problem especially on 2 way lighting circuits wired in the conventional way.
To rectify this you need to rewire the switches to the conversion method to elminate any induced voltage or fit a snubber into your light fitting.
the simple answer is induction, the long answer is capacitance...is the light 2-way switched? is it a particular long run from switch point to to light fitting, is the switch wire/s bunched with other cables. Is there an earth wire in the same switch feed, is the earth wire a 'good earth'
low energy are crap btw ...problems, problems problems...and dim -:)
beat me to it sintra!
hi, thanks for your replies,
this is a one way light switch, the other lights in the house can work quite well, no flickers, only one keeps flickering when turn off swutch...
errm is this a old house ??? wonder if you have negative switching i have seen it once energy saving lamps flicker and it was all swopped over worked then .. somthing to do with + side of the sinewave that makes the lamp flicker
I had this problem with a mirror light in a bathroom ,found that the light connections were incorrect and the L an E were reversed so may be worth while checking the polarity of the fitting , or its a dodgy lamp
Reply to lamp flashs when i turn off switch in the Australia area at ElectriciansForums.net
It does seem to me that there's a capacitively coupled voltage to each set of downlights (on the light side of the switch), and when you put the...
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
