Sounds like they " Don't Want " anything high up........ Our health and safety permitted the work with the use of a non conductive tower scaffold at a particular platform height.
with men on it earthed ?
Discuss Lamp post under mains pylon question in the Commercial Electrical Advice area at ElectriciansForums.net
Do the lamp post heads have a CPC from the supply connected?
eagles need to be more accurate.they ---- from a greater height.If i had to be reincarnated as a bird,i'd rather be an eagle than a seagull...
Wouldn't like to try it out for size though Percyprod.If it is an 11 or 33 kv line I wouldn't have thought they would be on pylons, they usually carry 132 and above. What is the distance from the lamppost top to the cable? I doubt the 11kv line would induce that much voltage.
I've never seen that stretch of road that clear...This is the M1 northbound just after the Hemal Hempstead junction you have the standard 12mtr (I think) then when the pylon goes overhead you have these 5 mtr postsView attachment 42839 You never said what H& S said last Tuesday and what is the distance between the lamp post head and the pylon?
Reply to Lamp post under mains pylon question in the Commercial Electrical Advice area at ElectriciansForums.net
