Lampholder with Cord Grip | Page 2 | on ElectriciansForums
Discuss Lampholder with Cord Grip in the UK Electrical Forum area at ElectriciansForums.net
glasgow
Hi
Wonder if anyone could be kind enough to give me some advice. I have bought a BG Lampholder from Screwfix. I was looking specifically for one that had a cord grip. The one I have is advertised as a integral cord grip but I was expecting the cord to be hand tightened in some way. I just can't see it. All I see is basically just a hole at the top that the cord goes through. Quite slack at that. I know that after I wire the terminals I tuck the blue and brown under the cable restraints. I don't if I am getting cable restraint and cord grip mixed up but I was definitely expecting the hole at the top to grip the cord. Any advice would be appreciated. Thanks very much
https://www.screwfix.com/p/british-general-cordgrip-straight-lamp-holder-bc/48002
If you need a dedicated cord grip (for a heavier than usual lamp - although you shouldn't put too much weight on the flex), you could buy a lamp holder with a threaded cord entry as these are meant to be mounted in some way, and then purchase a third party cord grip that screws into it.
These can be picked up quite cheaply from on-line lamp spares suppliers and come in a variety of colours. They can also supply more stylish lamp holders but be aware that if you choose a metal lamp holder, it's likely it will need an earth providing which obviously requires the use a a 3 core flex.
Reply to Lampholder with Cord Grip in the UK Electrical Forum area at ElectriciansForums.net
