It's just to lives with through lives though isn't it so in reality no matter how there switched it's not dangerous
...I would not normally get in the middle of one of these debates...but...your phrase of "lives through lives" is a worry...
Firstly,you will/should not have lives connected together. There will be lives,both permanent and switched,and there will be loads. Also,there may be neutrals,and earths.
One situation,where you will not have an explosion,or fuse blowing,but is nevertheless a concern,is where you may connect,inadvertently,lives from two separate circuits,say ground floor and 1st floor.
This would leave the possibility of a circuit remaining live,with its' labelled MCB,turned off.
It is for reasons such as this,you have received some posts,although jabbing at your pride, are given,in an effort to save harm.
If you would be generous enough to furnish the forum with your occupation,i will guarantee i can come up with a parallel question,which may give you an indication,of the quandary we are facing.
Regards :aureola:
