LandLadyLu saying Howdo
We have a problem in our front bar where a bunch of spotlights aren't working (the bulbs work in other fittings, so it's not dodgy bulbs),
well obviously the issue is the lights, there can be many reasons why, a dodgy switch, a dodgy connection, a dodgy circuit breaker, the only way is to bite the bullet and get an electrician in, forget the first one you employed, he sounds like a bad one, they are rare, there is no way we can sort this out for you on here without seeing it.
Having said that ...Photos can help/ My first check would be to see what type of fitting or fittings are used. Then also to see how they have been connected .Chances are its a "spur" . If it is and its disconnected . if its a track system etc for pro lighting etc etc . Just buy a new one and have it fitted .Who ever fits it should test it all back to the consumer anyway .
2 mins of Google and its obvious you seem to have pro lighting . Do you not have a house engineer/electrician at hand ? . Looks a lovely place !
LandLadyLu,
LukeD,
