Landlords supply outdoor lighting | on ElectriciansForums
Discuss Landlords supply outdoor lighting in the UK Electrical Forum area at ElectriciansForums.net
scotland
Hi there just looking for a bit of advice on a landlords supply within a block of new build flats my question is there is 6 outside lights which light up the path way to the bin stores. Now what I was thinking of doing is wiring them through the downstairs flat and drilling through and running my cables through there to supply the external lighting but will be powered from the landlords supply not the actual flat am I allowed to run cables from the land lords supply through a flat which will be occupied thanks appreciate any feed back in advance
I think as long as it’s labelled what it’s for, and stating it may remain live when the flats own electrics are isolated.
Oh… and is your username still your level of training, or are you into the top league yet?
Thanks mate, trade test in may been on here since I started thought by joining it would give me a bit more knowledge on my spare time you’ve replied to a good few of my post through out the years and I appreciate your help little spark
Reply to Landlords supply outdoor lighting in the UK Electrical Forum area at ElectriciansForums.net
if the 3 spaces with charge points are always allocated to the same 3 flats, surely the easiest way is to run the supply to the load side of the...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
