Landlords Visual | on ElectriciansForums
Discuss Landlords Visual in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Graeme Harrold
Just been to a property today to complete a visual inspection and found a couple of nice surprises -
- 32A ring with 4 terminated cables - out of curiosity I did end to end r1 which showed continuity on 3 cables
- Shower supply taken from supply side of the main switch, through chocblocks and off out to a 63A 30mA RCD......
Hopefully I get called back to sort these out.....:eek:
Reply to Landlords Visual in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
