View the thread, titled "Laptop earth-buzz audio fix" which is posted in Australia on Electricians Forums.
L
lecnoob
Ok - long story short. I do music shows and have power trouble using laptops for audio - earth buzz issues. My usual fix has been to find a replacement power supply designed with no earth pin on the plug - no more buzz. This has worked for the last few Toshiba laptops I had and is way cheaper than messing around with earth-loop killers or whatever.
So, my new Samsung has the usual problem, but now I can't find a 2-pin replacement power supply. I've been warned off just disconnecting the earth on the OEM power supply as apparently it might need it by design - though I have no idea why it should do when a 2-pin power supply works totally fine. Please correct me if I can just do this!
In desperation then I'm considering just swapping the tip over on my old Toshiba replacement 2-pin supply and using it with the Samsung - it's 19V and has enough amps. Is this a dumb idea? If not, can anyone tell me where I can buy a solder-able DC tip?
Many thanks!
(Tried posting this here first but doesn't seem like anyone there knows)
Yeah, I just wanna fix it at the source as I have 6 outputs from my soundcard that I may want to use - connecting directly to guitar amps, bass cabs etc.
Reply to the thread, titled "Laptop earth-buzz audio fix" which is posted in Australia on Electricians Forums.
