large 2 gang weatherproof switch needed. | Page 2 | on ElectriciansForums
Discuss large 2 gang weatherproof switch needed. in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have just fitted a BG 2gang weatherproof switch.
[ElectriciansForums.net] large 2 gang weatherproof switch needed.
At present only 1 of the gangs is in use to switch 5 x 200w LED floodlights.
I used 6mm 3 core SWA as it was a long run from the CU and Voltage drop forced the larger cable.
I only just got 2 x 6mm cables into the 2gang switch. In a year or the customer will want another 5 floodlights switched from the other gang, but I will not be able to fit another 6mm in there.
I have 3 questions:
1. Is there a larger 2 gang switch on the market?
2. Is there a larger back box that BG do that would fit on to the existing?
3. Any other ideas? Preferable not 2 x 1gang switches which will be the last option due to the layout.
Cheers guys.
Reply to large 2 gang weatherproof switch needed. in the UK Electrical Forum area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
