Hi all,
Used to doing small 2 bed and 3 bed new builds so cable sizing is never an issue
got a huge 7 deb house 5 floors to do in the next 6 months, had a quick look and now wondering what cable size to use, before i get the book out i thought id post here for more advice
4.0mm legs for ring then 2,5 or 4,0mm all the way, seems to be quite a bit more expensive than 2,5mm also on the lighting 1.5mm to feed the first point then 1.0mm after.
or other option is radials, seem to be getting more common now and some favor over rings.
putting a large 24 way board in for the extra rings and lighting circuits
any advise would be appreciated , also told me he wants the cables capped ggrrrr, you guys use oval tube or channel for this these days?.
Cheers
Grand
Cheers
Grand
