Large house 2.5mm or 4.0mm | Page 3 | on ElectriciansForums
Discuss Large house 2.5mm or 4.0mm in the UK Electrical Forum area at ElectriciansForums.net
Midlands
Hi all,
Used to doing small 2 bed and 3 bed new builds so cable sizing is never an issue
got a huge 7 deb house 5 floors to do in the next 6 months, had a quick look and now wondering what cable size to use, before i get the book out i thought id post here for more advice
4.0mm legs for ring then 2,5 or 4,0mm all the way, seems to be quite a bit more expensive than 2,5mm also on the lighting 1.5mm to feed the first point then 1.0mm after.
or other option is radials, seem to be getting more common now and some favor over rings.
putting a large 24 way board in for the extra rings and lighting circuits
any advise would be appreciated , also told me he wants the cables capped ggrrrr, you guys use oval tube or channel for this these days?.
Cheers
Grand
Thanks for the links - they clarify things. I talked with the head of BASEC at an IET meeting on ring vs radial wiring some years ago and he wrote to me and confirmed that FP200 and similar BASEC approved screened cables could be used running almost anywhere - but always on a standard type B 30 mA RCD protected circuit. Now fire-alarm supplies should not be RCD protected (as the voltinium article states) - so they have to be run in "protected" areas to avoid the likelihood of later nail or screw damage.
I'm not sure you've got the wording right there.
Thanks for pointing out my mistake. The voltinum article:
Fire alarm cables for use in thin walls or partitions - http://www.voltimum.co.uk/articles/fire-alarm-cables-use-thin-walls-or-partitions-0
actually points out that no routing of screened cables should rely on RCD protection alone with regard to cable protection - whatever the supply purpose of the cables. The article then goes on to point out that both FP200 Gold and FP Plus have thick aluminium sheaths that do pass the nail/screw penetration tests - so they may be run more freely (though of course with common sense!). Some other screened cables have an aluminised plastic screen and they cannot legally be run so freely as they do not pass the penetration test requirements.
Reply to Large house 2.5mm or 4.0mm in the UK Electrical Forum area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
