large shop with an rcd at the origin | on ElectriciansForums
Discuss large shop with an rcd at the origin in the Australia area at ElectriciansForums.net
hoover
......Set at 500ma. Now this supplies several dist boards serving quite a few circuits. My question is do I install individual rcds set at 30ma at every board or to reduce incovenience when a circuit trips do I put all circuits on rcbo's( think of the expense of over 100 circuits). A lot of these circuits will supply fridges\freezers so might be a lot of nusieance tripping.Also cables running down stud walls serving light switches. 30ma? Sounds like its going to be an expensive excirise.
Well basically the supply authority say they can no longer supply an earth so it's up to their customer to supply one and so making the system a tt. So just to clarify my main point --do I need to put all circuits which incorporate cables in stud walls, supplying light switches etc, on individual rcbos at 30 ma? Obviously these weren't required when system was a tnc. Now I know sockets and the like will be rcd'd and there will be an rcd at the origin if the installation but this will be set to 500 ma's.
Ahh......
well if they cant they cant. Is their excuse the theiving pikeys!!!!!
IDEALLY:
Armoured to each dist board and then RCBO's for each circuit.
Can that be done? How many DB's. how far. how much access to cable runs do you have. Is there a DB at the origin.
ps. just read "100 circuits". Hmm.
All down to what you have been asked to do / how much they are willing to pa. Do they want it saf-ER and cheaper, or future proofed?
The requirements for 30mA RCD protection are the same for TT as for TN installations.
Just because the installation is now TT, doesn't mean that 30mA RCD protection must be provided.
Unless you can establish a very low and reliable Ra(Ze), you will have to use RCDs to provide the disconnection times required for a TT installation, 1s for distribution circuits and 0.2s for all other circuits.
You will also have to ensure discrimination between the RCDs.
If earth leakage is a problem, then you may have to provide individual RCD protection and a separate earth electrode to each DB, with the exposed-conductive-parts related to the DBs connected to the relevant earth electrode, double insulation would have to be provided for the part of the installation, between the origin and where the RCDs are situated.
'they can no longer supply an earth' implies that they have supplied an earth but can no longer guarantee it's integrity, have you reminded them of their duty to maintain a previously supplied earth connection (in writing)?
Wow, thats an interesting read - how'd you get that!
So according to that (is it up to date? Sept 2007) they must fix the TNS earth .....
That's what I was getting at in post 11, this has as far as I can remember, always been the case with an existing suppliers earth connection.
Reply to large shop with an rcd at the origin in the Australia area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
