larger than usual 2 gang KO box? | on ElectriciansForums
Discuss larger than usual 2 gang KO box? in the UK Electrical Forum area at ElectriciansForums.net
Karin
Kent
hi all, not been on here much recently as i've been away from electrical work a bit due to injury (not from work :p ), but got a quick question for more experienced eyes than mine.
got a message from a friend wanting to find a blank plate for a flush metal box with the dimensions 100mm x 160mm. it's been used i think as an entry area behind an old wall mounted appliance (possibly shower unit or something) so never had a matching faceplate.
it looks the same as your standard (~85x140) 2 gang KO boxes - has just the two screw threads one at each end, but is just slightly bigger in each direction.
obviously i've been through the obvious suggestions (hang a picture over it :D) but it got me curious as i haven't been able to find anything that size after looking around a bit. does it ring any bells for anyone?
cheers guys. good shouts streamer and Dave, the picture i saw was in a tiled area so bathroom or even cooker area is possible.
yeah i did suggest exactly that Gavin, if it needed to be waterproofed. a nice coloured perspex or something and make it a feature!
Paint it and use it as a little inset soap dish. Tell your neighbours it's 'vintage' and 'industrial' etc. etc. They'll all want one.
Reply to larger than usual 2 gang KO box? in the UK Electrical Forum area at ElectriciansForums.net
People who claim to be plumbers... and tilers... New bath fitted and the drain is accessible from the side and there are isolating valves on the...
