Latest Acquisition and it's mint. | on ElectriciansForums
Discuss Latest Acquisition and it's mint. in the Electrical Tools and Products area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
H.W,Sullivan, type of Wheatstone Bridge . Son found it on faceache or some other anti-social gossip site. ÂŁ15. Guess it's age to be about 80 -90 years. Lucien would have been able to give me some info., like what voltage battery etc, but any info appreciated.
Google tells me that the company was founder in 1897 , manufacturing telegraph machines.
  • [ElectriciansForums.net] Latest Acquisition and it's mint.
Looks like the meter has been "upgraded" on yours Tel,
V126 4.5v battery from the link below, unless your has been modded for 4 x "C" cell as pic below.
only problem is it's listed as "out of stock".
ordered a 4.5V flat bugger , like wtah you had in a bicycle front lamp in the 60's,if we ever bothered with lights back then.no lights on bike made it harder for the bizzies to find us.
Very nice!
As you probably gathered it can measure resistances very accurately. Usually as accurately if not more accurately than a modern MFT. It can also do Murray loop tests to predict where a fault is.
Basically if a cable is faulting to earth, you join the conductors at the far end and measure the resistance as usual.
Then you'd switch to "Murray Loop", and the negative battery terminal would presumably need connecting to a good earth.
You'd then measure again. From these two values, and the formula in the manual, the distance along the line that the fault is can be calculated.
A Megger BR4 manual (which I found online as I have one) would fill in some of the blanks about the concepts.
fitted a 4.5V battery. sadly, no matter what I do with dials and switches, there's no response from the galvanometer: stuck on 0. it's not locked as the zero adjust moves the needle. going to open the box and see if there's anything glaring,
The most likely is that the galvanometer has become damaged.
As it's removable you could try testing it directly by cooking up something like this.
Make resistors P, Q, and R the same and S about half the value. It should move.
Or just stick an AA battery across it!
going to open it up tomorrow - see what's what. will gry above first option.
A bargain indeed if the below is anything to go by:
update.. opened it up and found this. galvo has deffo been updated as it has a PCB and on it there's a 8 legged microchip. there's 2 sets if leads coming off ending in 2 PPÂŁ connectors, but no connection to the internals of the machine, and no apparent place for them to go. pointless fitting PP3/s as would just be a stand alone galvanometer . Any ideas???
further investigation finds that the 2 securing release pillars for the galvo are actually terminals, connected to both the galvo and the internal resistor banks. tomorrow will try and see if connecting 2 PP3s will get some life into it. if i read it right, maybe someone has modded it to use PP3s instead of the original battery, necessitating the removal of the meter to replace said batteries. weird.
Reply to Latest Acquisition and it's mint. in the Electrical Tools and Products area at ElectriciansForums.net
