Leakage current meter - recommendations? | Page 2 | on ElectriciansForums
Discuss Leakage current meter - recommendations? in the Electrical Tools and Products area at ElectriciansForums.net
Trouble is last time I checked ( last year) there were a handful of companys that made type B RCDs, Doepke was one of them, they were also over ÂŁ100 each. Not sure if much has changed
I hope the IET are not following this post.....lads are going to well miffed,if the 19th has them dragging an oscilloscope to every job :)
Lol. I doubt they are but they do seem to be pushing untestable tech from manufacturers.
@pc1966 thanks for that, You don’t know if any of the megger range measure dc do you?
I think the DCM340 does, but it appears to be only a 400A range so your resolution is something like 0.1A and no good for leakage checks.
[automerge]1588327044[/automerge]
Great for PV or car use though!
Reply to Leakage current meter - recommendations? in the Electrical Tools and Products area at ElectriciansForums.net
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
