Leave existing ceiling rose within new metal light fitting?? | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss Leave existing ceiling rose within new metal light fitting?? in the UK Electrical Forum area at ElectriciansForums.net
Northumberland
I'm your average DIYer and after advice about replacing a pendant light with a new flush metal fitting. I can fix the new light to the ceiling and the existing rose sits within the void of the new fitting without any clearance issues. Is it OK to leave it in place and wire the new fitting into the rose replacing the pendant's connections? I've had mixed replies from other forums. If I can't do this can I use wago connectors or choc blocs and leave them in the fitting or does it all have to go up into the loft space within a junction box? I'd much rather just connect to the rose and leave it in situ and I can still get a good fixing for the bracket. Thanks in advance.
[ElectriciansForums.net] Leave existing ceiling rose within new metal light fitting??
I think using the existing rose as a connection point is much better (and easier) than joints in the ceiling void. The most important thing is to test for earth continuity of the new metal lighting fitting, when it's all finished.
Thanks for that but I’m very much your average DIYer so not sure how to test this and sounds like I’ll probably need a multimeter.
I'm afraid that's where DIY electrical work reaches it's limit. Electricity is a lethal form of energy - in untrained hands.
Whenever electrical work is carried out, no matter how small the job, the only way to ensure safety is by testing on completion. This needs proper calibrated equipment, in trained hands, with knowledge of the safe limits as specified in the Regs.
The only way to ensure your work is safe is to get a qualified electrician to test it for you.
generator,
that is a little bit extreme to get a qualified sparky just to change a light fitting!! ;)
mark if you want you can buy a cheap multimeter for about 8 quid then just plug the red probe into the live terminal and the black probe into earth terminal. if all is well it should work however if there is a break in continuity then you will need a sparkie to do some fault finding.
Must admit I think changing a light fitting shouldn't be a problem for the competent DIYer. It's about knowing your limits as well of course.
Would you also stop someone fitting a 13A plug? (plug-top for the benefit of certain people :)).
Tin hat on. And tested.
Alban and DPG,
I'm surprised at the lack of " you need to get an electrician" type replies to this thread - they're quite common on many other similar threads I've seen in the past. Installing a fitting like this one is well within the capabilities of a good DIYer.
However - knowing the hazards involved and how to avoid them is another matter entirely - that's where electrical training is vital.
Knowing about earthing , why it's important, how to achieve it and how to test to ensure the loop impedance will be low enough to disconnect the supply in the event of a fault - that's where training and knowledge of the regs comes in. The OP admits he's only an average DIYer. 13A plugs? - well, at least they're not made of metal!
Mark,
You are installing a metal cased fitting. If a fault occurs on it some time and the connection to earth is not present or of the correct maximum ohmic value, the exposed metal parts can become live. This could be lethal for anyone who touches it. The metal must be connected to the earth conductor at the ceiling rose terminal - that's simple and you've done it. However, you then need to know that the connection is healthy all the way back to the main earthing terminal in the consumer unit which feeds the light. It must have a certain maximum impedance, so that if a fault to earth occurs the current will be high enough to trip the circuit breaker ( or blow a fuse) within a prescribed minimum time ( usually 0.4 secs). This is where testing is essential.
This is why I suggest you ask an electrician to test the completed work for you. A little knowledge really is a dangerous thing !
Sorry if I come over a bit strong, but electrical safety really is a matter of life and death.
I can see your point Generator, but I still maintain that a light fitting can be changed by a competent DIYer.
I fully understand electrical safety and have often been called on to advise on such matters.
A question - do you think people should be able to change brake pads on their own cars, assuming they are aware of the dangers?
I understand both your points. We are currently decorating the house room by room and also plan to change the cheap 20 year old plastic light switches and sockets for metal ones in every room. I think it may be a little overkill to have an electrician check the light fitting I’ve just fitted by itself but I think it’s definitely worth doing when I’ve managed to get round the whole house.
DPG,
the point is, it's a metal fitting - need I say more? As for brake pads, I've done plenty myself (filthy job!). Able is the operative word. At least you can see it's done properly - given the knowledge and experience that is. Needs a quick road test to be sure though!
I let someone else do it these days - one hopes they use the rolling road tester!
Mark,
good idea - just don't touch the fitting till you've had it tested!
Generator, nobody can SEE if a bolt is done up tight enough when they've done work on a car's brakes. Same difference.
And by the way, the garage that change your brake pads won't test it on a rolling road afterwards!
DPG,
Mark,
you mean you don't fix the brakes on mother-in-law's car?? a missed opportunity there, my friend. :mad::mad::mad:.
Reply to Leave existing ceiling rose within new metal light fitting?? in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
Any professional forum member in or near Somerset help out? Needs a little more help than we can offer from afar.
Recommended Sponsor News
Hi everyone,
