LED 6FEET GARAGE LIGHT BATTENS | Page 4 | on ElectriciansForums
Discuss LED 6FEET GARAGE LIGHT BATTENS in the Lighting Forum area at ElectriciansForums.net
Is this another case of " I have a problem? I'll start changing everything in sight, rather than get someone into to do some testing and fault finding?"
Considering the cost and difficulty (inconvenience of having to take time of work etc.) of getting someone in it doesn't seem an unreasonable first step to try to isolate and identify a failing device by substitution in the first instance.
Of course, it does little to identify a fault with the wiring (although it can often offer a suggestion) but then how often does the wiring fail compared to the device connected to it?
Reply to LED 6FEET GARAGE LIGHT BATTENS in the Lighting Forum area at ElectriciansForums.net
Hope you get better soon .sounds quite serious
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
Sadly not very near Swindon! I'm in Oswestry. Thanks a lot for the thought though!
