Led Driver test | on ElectriciansForums
Discuss Led Driver test in the Lighting Forum area at ElectriciansForums.net
PiersG
London
I bought a replacement LED Driver that i thought would do the job but nothing. Ive test the leds all ok, input to driver ok but cant get a reading on the output of the driver. Am i setting the multimeter wrong?
Have i got the wrong led driver?
Or is the new driver faulty too?
New. Driver output: DC45v/0.35A cc
Old. 350ma cc P rated 12.95W
Thanks.
Just read another of your replies on another thread. Looks like the output voltage of the old driver is 50V max and the new driver 45V max. Will that cause the issue even though the lights are using 23V?
Still not getting a reading out of the driver!
might just be that the new driver has insufficient voltage output. had similar, old driver was 85V max. a 80V max driver would not work. a 90A driver was fine.
Reply to Led Driver test in the Lighting Forum area at ElectriciansForums.net
Assuming the electrician checked the new driver was capable of supplying current (in other words it provided an output voltage and curent when...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
