LED DRIVER | on ElectriciansForums
Discuss LED DRIVER in the Commercial Electrical Advice area at ElectriciansForums.net
scotland
hi guys panel lighting which has a driver in them above a foam tiled office my question is that the twin and earth feeding the driver is not earthed my some people are saying well a pendant dosent have an earth what do you guys think
You mean the earth is cut off, or it’s just a twin cable with no earth?
Regs say there has to be an earth at every point, even if it’s not required, and connected through if it’s a loop in/out cable.
The driver is more than likely class II and doesn’t need it.
pendants and lamp holders have a bs number all of their own...
Where else can you have a hole big enough to stick your British standard finger in and touch live parts
if the driver doesn't have an earth terminal, the earth should be parked in a choc block or wago, and if 2 cables at a fitting, the earth should be continuous to the next light and on and on to all fittings
Reply to LED DRIVER in the Commercial Electrical Advice area at ElectriciansForums.net
Hello. This is such a noob question, but I'm struggling with something that seems like it should be fairly straightforward. I have numerous 24v...
Thank you so much for your help I appreciate it alot. I learnt alot and saved alot of money in the progress kudos. Best wishes to you too.:bowing:
