LED Flame-bulb >>> X-10 (In)compatibility? | on ElectriciansForums
Discuss LED Flame-bulb >>> X-10 (In)compatibility? in the UK Electrical Forum area at ElectriciansForums.net
CCinPA`cr
EF
United States
A Holiday emergency! ? I purchased LED flame-bulbs:fire: for my outside light-fixtures. But instead of "flickering"... ⚡ They just pulse on/off. ? I'm thinking the problem may be caused by the X-10 :link: switches that control the bulbs?
Help? ?
the X-10 would likely use a semi conductor to switch on your light,
(this is the problem) it is not compatible with the electronics in the flame bulb.
so use the x -10 to control a relay and use this relay to switch on the flame bulb.
[ElectriciansForums.net] LED Flame-bulb >>> X-10 (In)compatibility?
Thanks for all the help! The solution looks a bit weird... But it works!
Reply to LED Flame-bulb >>> X-10 (In)compatibility? in the UK Electrical Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
The lights are on a circuit with other lights, which is a different circuit from this receptacle. Both of these circuits and others are on the...
