Led gu10 bulbs | Page 3 | on ElectriciansForums
Discuss Led gu10 bulbs in the Australia area at ElectriciansForums.net
H
hduz5
Hi guys,
Anybody used a 7 watt led bulb? Any comments on the light quality? I've tried a 6 watt Aurora bulb which was sold to me as a 50 watt equivalent. It isn't awful, but it is definitely not equivalent to 50 watts. Also, if anyone is involved in r+d
on led bulbs are you expecting to see brighter bulbs on the market in the next year?
Cheers
Recently fitted some Aurora Solar LEDs they all come fire & bathroom rated as standard & give off a a good, bright, warm white- unlike some which claim to be warm white, but are 'orrible and shadowy
Are you affiliated to the seller at all???
Absolutely not! Separate sellers sell them in packs of 5 and 10 for about the same price each. I've also used dimmable ones from other suppliers, but they are very much more expensive. The only reason I suggested the ones from eBay was because I have used about 20 in different houses to replace 12v halogens which were failing due to overheating (and melting) of the terminal blocks and faulty transformers. It seems like a cost effective long term solution.
Look into ones that use the SMD 5050 chips, great output from them at a low wattage.
Nice spread of light off them as well unlike the high powered LED stuff which can be very direct.
Just fitted 28 of these in a property, gives out a lovely light. Only problem is 16 all blew in one go, a week after installation. Made wholesalers send someone from manufacturer out to replace all lamps; have been perfect since.
t
Halers all day long.
Also if anyone is going to be fitting any Arteor- by Legrand home automation systems, this is one of the only downlights on the market that is compatible with their dimmer modules.
OK - what is the deal with everyone wanting a wide angle bulb? surely if you want a like for like replacement for a halogen that you should seek a anti glare bulb? Those SMD bulbs are fine for low ceilings and narrow hallways but in large rooms a narrow angle would be preferable - right?
I like this for high ceilings - throws the light into a nice focused area:
[ElectriciansForums.net] Led gu10 bulbs
Reply to Led gu10 bulbs in the Australia area at ElectriciansForums.net
