LED Lighting | on ElectriciansForums
Discuss LED Lighting in the Lighting Forum area at ElectriciansForums.net
Dubai
Hi,Im just a fresher as design engineer. While browsing, I read that 330ohms resistor has to be placed parallel across an LED light, can someone tell me if it is necessary and why?
Thankyou @static zap @HexHex :)
So do resistors have to be kept both parallel and in series..
How do I discern the values of the transistors and is it a mandate for LED Retrofit?? I intend on retrofitting with Type B LEDs and so would bypass the ballasts but the same fixtures.
I have no firm value answers , inrush is very dependent on actual device used ,and quantity that are simultaneously switched. (Industrial/factory situ)
Resistors are in-efficient , practical solutions may involve
NTC or PTC devices when you better understand
which problem (Inrush I /nuisance blinking is being solved)
( apologies my answers are for thought /design concept
rather than a practical design)
Reply to LED Lighting in the Lighting Forum area at ElectriciansForums.net
Flange and nuts in the same sentence. Jeez I really must start acting my age.
Thanks, No, I didn't use thermal paste, but I didn't run the LED at full voltage, I used a controller and it wasn't running hot . I used an LED...
