StevieTee
Guys, looking for some help here.
I done some work for a customer installing 11x 8.5W ip rated dimmable downlights with a dimmer switch for his toilet.
Anyways, I had to go back yesterday to finish up work for another part of the house. when getting there, the guy tells me that the tiler says that the lights went off and on once for a brief second, but to a very low brightness and he had to turn the dimmer off and back on again to put the lights back up to full brightness. This happened after about 5 hours of having the lights on. So, i checked everything out, all looks good, re connect everything and test results were fine. So I suggested changing the dimmer switch to see if that's the problem. Done this, no problems with me all day whilst Im there.
Get a phone call tonight, oh, the tiler says the lights went off and on again.
Im still new at working on my own, but I really can't think what else is causing the problem. I don't know if its the tiler talking rubbish to try and make up for the fact he should of been finished last week!
Does anyone have any suggestions? I did notice that they have all the upstairs lights on the same type of dimmers too, which have all the same LED lights installed and none of these cause problems.
Any one got any ideas from their past experience?
